Jonny_H
We have used a Brita Filter and will be taking one with us. They are excellent and have the advantage that the jug can stay in the fridge and therefore you have a supply of chilled water too!
I think between the huge tanks, the Brita filter, and bottled water we should be more than ok. 2 litres each in bottled water sounds good. Our current 'bottled water' tank holds 5 litres, as there will be 3 of us on the Atlantic leg we will aim to use 1 5 litre bottle per day (this giving just under 2 litres each) - it should therefore be easy to monitor useage too.
Thanks for all the replies.
Incidentally - I do appreciate that most tap water is fine to drink, however 3 people with iffy tummies at sea doesn't appeal! Also, as Jonic noted, if you loose a water tank you are seriously hindered. Our main 90 gallon tanks are split so we have 35 gallons in the tank which the pumps draw off, and 55 gallons in seperate tank which sits between the deck filler and the smaller tank - this works well as we can fill the tanks, then close the valve between the 35 and 55 gallon, knowing that when we use the first tank we can open the valve, refill the 35 gallon tank, and then repeat when we've emptied it a second time.
I'm probably therefore going well over the top on water - but it is very important, so 90 gallons of tank water plus 5 litres per day of bottled water (for 3 people) it is.
I'll look forward to the long shower when I get to the Caribbean!!
Jonny
Jonny
