[70521]
Use the tank water all the time and I'm not dead yet. OK 95% of the water is boiled for tea or coffee.
Interesting that in all the posts nobody has said that they have got sick from drinking water from the tank.
... I have a TDS meter from a previous hobby, which shows the same TDS of just under 300 ppm for my tank water that it shows on tap water in the flats* next to the marina. Occasionally I check this, mostly as demonstration while "I'm not drinking from your tank, EWWWW" people are visiting the boat.
* Actually the flat had a problem with something leaching in from the pipes and you had to run the tap for 1-2 minutes before the water stopped tasting funny and dropped below 300 ppm. Funnily enough, most people would happily drink that.
Water from the tanks, beer from the fridge. We don't use any chemical purification but do have a Seagull filter at the kitchen tap. Tastes good.
I changed all my knarly 1970s water pipes, tap etc. over winter and scrubbed out the fresh water tank (that was already very clean to my surprise). We have a Whale Aqua Source Clear Water Filter fitted just below the tap:
http://www.piratescave.co.uk/whale-aqua-source-clear-water-filter-12mm.ir
My most awesome crew and first mate (the wife) insists on bottled water, which is just a huge waste (apart from as a backup of course). We always run the hose for a while before filling the tank to make sure we get none of the nice green sludge that grows in the pipes in this nice hot weather we are having. Considering we have some of the best drinking water in the world, is there any reason she should be shy of drinking water from the tanks on board? Does anyone add anything else to their water tanks, purification tablets, err, or something?
The Head Mistress, who used to post here always recommended that you did preventative cleaning on a tank and water system.
So I pour in 2 mugs of thin bleach and fill my tanks about a 1/4 full or less. I then run the taps through and then them off and leave the bleach solution in the pipe for 12 hours. I then pump all the water out and refill tanks.
The water will smell of chlorine for the first 2 fills, getting much less second time round, but it cleans the whole tank. I do this once a year.
Mid season, I will add 1/4 cup - that will smell but you can still use it for washing, kettle and drinking as the chlorine will evaporate off very quickly in the air if a jug of water is left to stand. Her indoors doesn't like the smell......... but it soon goes and the concentration is so small as to be harmless.
The result is that the tanks (and pipes) are very clean.
Edit: Do I drink the water - I am happy to do so, but we normally drink chilled bottles from the fridge. Med water is mostly potable but can be salty - but that makes excellent coffee!
A friend of mine was working in Saudi in the 70s at a remote camp. A tanker came once a week to deliver water. It wasn't until some time later that he found out that the tanker also emptied the cess pit and took the contents back on the return trip.
7. Allow some solution to escape though the vent, if safe and applicable (some boats use the vent as an over flow, while in some cases the vent is in the interior). This will sanitize the vent line.
