Drilling holes through a bulkhead very close to a deckhead?
CaptainBob
7 Nov 2007
North Yorkshire
www.yacht-forum.co.uk
Hi,
I need to drill some 8mm holes through a bulkhead, very very close to my deckhead. My quite small cordless drill doesn't allow me to get high enough up for the holes I need to drill. Is there some adaptor or something I can use to solve this.
Holes need to be circa 20mm to 25mm from the deckhead maximum. And they need to be parallel to the deckhead, so I can't drill up at an angle to solve this.
TY
CB
Lidl had this one on offer recently for £4.99....... with luck they may still have them
For details see http://www.lidl.co.uk/cps/rde/xchg/lidl_uk/hs.xsl/index_38190.htm
A lateral-thinking alternative would be a hand drill, if you have an old one knocking about. I think mine would get within an inch of the deckhead as required.
I dont know about lateral thinking. Probably what I would do anyway although I think I have a right angle drive somwhere.
Some smaller hand drills may not take an 8mm drill bit but my Stanley one will.
Always works away from power supplies and never has a flat battery!
Indeed - I would only ever use my Makita cordless (or one of my selection of mains drills) for planned jobs, but the boat's toolkit for unplanned repairs contains a hand drill for exactly this reason.
Hi,
TY
CB
Maybe I can sort you out.I have a flexible drive that I don't need.It's this one exactly.http://www.ebay.co.uk/itm/BLACK-DEC...Home_Garden_PowerTools_SM&hash=item35c35baf6c.
You're welcome to it for the postage.How large are the holes you need to drill?Edit 8mm,It only goes up to 6,5mm.You can have it if it helps anyway.
I have one of those.Expensive(about £170) but it's got me out of a few tricky situations.
Maybe you can rent one.
After trying various adaptors as listed earlier which are basically useless I bought a similar 18v Ryobi and it is one of my most used tools along with the fein, worth the money.
Did a google, watched the "Fein MultiMaster" YouTube video. It said, and I quote, "SAVE UP TO 80% LESS TIME WHEN RENOVATING TEAK DECKS" :D
I assume that was a mistake :) Tool looks good! Could be a very handy thing to have. Are they all much of a muchness or is the Fein one "the dogs"? I usually prefer Makita - not used Fein.
(NB. Not buying one of these now but will add one to my birthday wishlist I think)
