pessimist
I need to drill some stainless tubing and rather doubt that my cheapo bits will suffice. Suggestions?
Thanks,
Colin
Thanks,
Colin
Thanks,
Colin
High speed steel is OK but drill at low speed and do not allow the drill to rub, the drill must always be cutting otherwise the drill will blunt quickly and the stainless will work harden.
I have found if drilling with a hand drill speed of the cordless drills seem about right for drills up to about 10/12 mm dia, mains drills tend to be too fast or don't have a enough torque at slow speeds unless geared down.
A battery drill is often slow enough if the hole is say > 10m/mWhat has not neen mentioned is that an ordinary electric drill say 600-800w tends to run far too fast for drilling stainless and if it does grab will stall the drill. A bigger drill say 1200-1600w will go slow eniugh and with enough torque to do the job. I have had very mixed results drilling stainless and when I started using a bigger drill it was a real revelation. My pillar drill although ot looked big and capable was still only a small motor which went too fast and was useless on stainless.
Cobalt bits. Low speed and much lube
