Seastoke
Well watching our marina dredge and pump it in to the estuary as tide is going out ,does it work or does it stop in estuary ,then come back in the marina .it just seems an ongoing issue ,how does your marina del with it
You pump it out and it goes and settles under my boat in the harbour you clowns!
Well we pay more money so have more rights than the yocals
To answer the original question, certainly much of it goes out: fast flowing water will hold and carry much of the silt (and larger particles), which will then fall to the bottom when the current slows (which is why you usually find a bar across the mouth of a river where it widens). Less of it comes back in because there isn't the flow speed outside to pick it (or as much of it) up. (Local circumstances will vary, of course, but the basic mechanisms at work remain.
But it's not just the amount or type of dredging (and commercial traffic) in the harbour itself that affects silting. Much is caused by changes in land use upstream over long periods. Changes in agriculture (direction of ploughing on slopes for horses vs. tractors, greater extent of ploughing, reduced field margins and fewer hedges, etc.) mean more soil is washed into rivers than in earlier days; water abstraction for agriculture, housing and industry reduces the normal flows of rivers (so they can't carry away the same volume of silt); etc..
