stelican
In that case,Would the engine also need frost protecting if running in river water.Hi. Just on that subject. If your s24 is a petrol engine and has the usual set up with the hot water tank being also heated by the engine, make sure you take the supply and return pipes off and blow through them to get rid of the water sitting in them and the coil inside the tank. Hope that helps, should it apply.
