alt
OK so I don't have the right word, but you know the circular stainless steel part that hold the out-drive / steering helmet together?
On the DP290 drives, to remove this you un-did the 2 allen bolts and used the 2 bolts from the outdrive upper casing to push it out.
Is it same for the DP-G? Just the bolts from the DP-g upper casing are a lot shorter!
Many thanks.
Many thanks.
