tobble
\'double\' glazing...
would appreciate the forum's opinion on the following idea;
Living aboard, I get significant problems with condensation. A dehumidifier mainly cures these, but I anticpate atime when I won't have access to mains.
I intend to improve the insulation (GRP hull) which should reduce the problem if not cure it, but have been wondering about windows - please save more general comments about the condensation issue for another post /forums/images/graemlins/smile.gif
One idea I had was to replace the windows, currently toughened glass in alu frames, with acrylic or similar, but instead of just one sheet bolted to the outside, also have a second bolted to the inside, so the coach roof side is 'sandwiched' between two layers of acrylic, and the grp forms a gap, to give double glazing...
problems with this might be condensation between the panes, minimised by a) sealing it on a day with low RH, and b) including some silica gel like wot comes with your new shoes.
another issue would be mosture ingress into the edge of the grp but that's easily sealed with epoxy and/or paint...
Am thinking about trialling the idea on my forepeak hatch, which is grp.
any opinions?
any opinions?
