jrt123
Does anyone have any good solutions to the following? I'm currently fitting a new outboard well to an old Memory 19 ( 19 foot gaff rig) the boom projects over the stern and the existing mainsheet uses a horse to clear the tiller from the transom hung rudder. An outboard in a well sits higher and requires a taller rudder stock, with a curved tiller to finish at comfortable hand height. A horse to clear this would be high and ugly so is normally replaced with blocks on the aft decks. This can give 4:1 with 2 blocks on the boom but finishes by cleating at one side. This is not so good for the other tack where the sheet is not to hand in a gust and so I would like to fit a double ended mainsheet. The only way I can think of requires a double block on the aft deck in the centreline and the tiller is in the way again. Is there a way around this that I'm missing?
