Nick_Pam
Most estemed fellow Forumites,
Again I seek your support on a technical matter that is perplexing me somewhat...
We have a 2006 Doral Boca Grande fitted with Volvo D-4's and DPH legs....on starting the engines and leaving to idle, I have discovered that over a period of about couple of minutes or so, my outdrive legs "wander" from the centre position across to full right-hand lock and if I apply full left-hand-down, the same thing happens (but over a longer period of time of course).
Whilst out on the water, the boat will track straight providing that I continually apply some "left-hand down a bit", needing to correct by one full revolution of the wheel every couple of minutes or so.
I have checked the rams whilst the boat was out for a wash and brush up a month or so ago and there does not appear to be any leakage of steering fluid - the reservoir is topped up to the full mark, and the Volvo steering ram gaiter (mentioned in many posts here previously) is in place as fitted by the dealer.
Am I haunted????
Or is there some sort of adjustment in the system which is badly set, allowing one of the control valves to open slightly and cause the symptoms I have described?
Or is it worse???????? :-(
As I recognise that the steering oil is used in a recirculatory way, I can absolutely see (theoretically) how this could happen, but I've spent ages in the engine room and can't see anything obvious that might allow some sort of adjustment.
I've searched the D4 / DPH manuals, the internet and this estemed site but can't track any obvious clues or conclusions....you help would be most gratefully received.
Regards and fingers crossed
Nick
Am I haunted????
Nick
