Don't try this at work..(NB)
Re: aaaargh
Thankyou... I'M FREE!!!!!!!/forums/images/icons/laugh.gif
Also thanks to the several people that PM'ed me the combination./forums/images/icons/laugh.gif/forums/images/icons/wink.gif
Cheers
<hr width=100% size=1><A target="_blank" HREF=http://arweb.co.uk/argallery/alistair?&page=1> My Pictures, Look if you want.</A>
Stuck
Stuck on two points : even after reading the thread.
I can't get under the bed for the second battery
The url takes me to a yellow page with only "Takagism since 1994" written on it.
John
Re: Stuck
No probs, i'll help you/forums/images/icons/laugh.gif,,,,Get view from foot of bed, toward corner of room (not side on view of bed). Click around the bottom of was above skirting board, this takes you behind bed.
The title gives you a clue as to what the combination is, when you get to the safe.
See easy./forums/images/icons/smile.gif
Re: Stuck
I never at any stage get a view from the foot of the bed ??
Other questions ?
Do these serve for any purpoes :
Key under cabinet,
CD case?
Or am I just thick?
John
Re: Stuck
click on the walls near foot of bed, you will get a view from foot of bed.
Key is used yes, cd case is of no use, ignore it
<hr width=100% size=1>Utinam logica falsa tuam philisophiam totam suffodiant
Re: Stuck
Ok, looking at the CD player, point your mouse at the wall to the left and click on it. Next, point your mouse to the bottom left-hand corner of the wall and click between there and the bottom of the bed. You should now see the battery on the right hand side of the bed.
You need everything except the CD case which is a red herring(well actually it's a CD case).
Re: Stuck
Hits ! (anag)
I have pressed I don't know how many times on the cross that the shadow is pointing to and each time it brings me back to the CD player ??
John
Re: Stuck
wait until the movie has finished. Completely finished! just leave the cursor on top of the cross to keep your position.
Re: Don\'t try this at work..(NB)
See... Told you it would drive you nuts!
Paaul
<hr width=100% size=1>Paul
<A target="_blank" HREF=http://www.polarity2.com>http://www.polarity2.com</A>
OSTAR 2005
trying to get everyone through it drove me nuts! <g>
"mystery of time and space.... stuck on level 12 where there are three laser gates can get through the first but not the second or third. found buttons with three colours but still cant get the other lasers to shut down??
Now Brendan, My Dear chap/forums/images/icons/smile.gif
Albartus/Motas/forums/images/icons/laugh.gif. I've got the screwdriver, Key and the Picture of the Sexy lady, Now what do i do?
Ok, I'm in the second room, Got the Floppy disk in the box, and the pin of the flag, how do i get the box open to put the disk into the pc?
<P ID="edit"><FONT SIZE=-1>Edited by alistairr on 02/04/2004 09:49 (server time).</FONT></P>
Take screwdriver to painting. Will unhook painting and give you screw. Slide poster under door. Using screw will push key out of lock on to poster. Slide poster back. Unlock door.
Use screwdriver to open panels under the red buttons. Use wirecutters to cut green wire. Second laser fence will close down, and you can move forward
Thanks,
In the room where you got the screwdriver and key - look to window on left - small black triangle where it meets the ceiling. Click on it- hidden
passage. Dopn't go up passage. leave the room and go back to the first room where you hit the red button. Now hit the blue button. Back out to corridor, click on the shelf to move it and reveal another passage
