matnoo
I have bought an outboard on ebay, this one to be exact a yamaha 9.9, 80s/90s model
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?V...58055%26fvi%3D1
I am restoring my boat and need to replace the transom bracket, which is no problem, but i need to know where should the waterline be?!
There is a cavitation plate, then 4 inches above that, another plate, and 4 inches above that, another plate (you can just about see them on the main photo)
Am i right in saying the water line needs to sit inbetween the two upper plates?
For the transom, im CNC machining it out of 50mm thick marine ply, bonded together with pva based glue, screwed with long stainless screws and bolted with M10 boltsthrough the fibreglas hull in 6 places. Is this adequate, I recon the motor is about 50kilos, 7stone
Mat
Mat
