Domestic water pump
If you mean keeps cutting in for a few seconds could be the valves in pump letting the pressure leak back though the pump if you are sure there are no leaks.
Probably a service kit available.
Had the same last year- it turned out to be the pressure relief valve on the calorifier was letting by. Took a long time to find and ended up being a bu*ger of a job to sort due to corroded fittings etc!!! May be worth a look.
