Elemental
Hi. I have a domestic water pump (about 8 years old) that is connected to two tanks - fore and aft. When a tank runs out (and the pump sucks air) it can be the devil's own job to get the pump to start drawing water. I can usually get it to work by sucking like crazy on the galley tap, but it's hardly ideal and yesterday I failed completely. Eventually, I got it working by disconnecting the pipe from the input side of the pump and sucking water through the pipes from the new tank and quickly plugging it back into the pump,
Subjectively, the issue seems worse when engaging the aft tank. And when running on that tank there's some spitting and aeration that results in the pump running for a second or two after the tap is closed. I suspect therefore that air get's in or there's some kind of blockage in the pipework to the aft tank. But I can't find a leak anywhere. One thing I wondered about is whether there's some kind of inline manual pump I can insert into the pump feeder pipe to manually create a stronger vacuum than the electric pump itself is capable of as a form of priming after a tank change?
