Blackbadger
New Member
Hello,
We are liveaboards and in the process of building our floating home and now installing the hot water supply so we can use an on-board shower facilities instead of marinas. I have fitted a domestic stainless steel indirect cylinder which will plumb into shore power. This is a brand new installation as the boat is an unfinished project.
Whilst completing the plumbing and designing the supply I am wondering if anyone has successfully heated their hot water supply using plumbing into the bowman heat exchanger, redirecting the waste water after the exhaiust manifold through the cylinder coil then return to the wet exhaust. What i am unable to find is the water temperature post exchanger. There are examples of raw water cooled engines adding extra pumps which I would avoid. This would be pressure fed using the jabsco raw water pump, the only alterations needed would be to extend some hose, poetntailly lagging the supply from the engine to coil retaining the heat.
The tank would be connected via rubber hoses and is mounted on a wooden platform, the 220v supply via galvanic isolator should help prevent galvanic corrosion (obviously leadinga a separate discussuon).
Logically this seems to be the simplest method without diverting the closed water supply, complicating the plumbing and at worst, easily to refit the existing loop (which will be retailed) in an emergency should that side fail. Having read about localised cooling and having a ford lehman where overheating could be a problem this method will negate the need to alter the basic cooling system setup which seems fine. Another logical advantage is the engine not heating sufficiently ot taking longer may be a problem like to smoke until reaching operating temp.
Or simply bite the bullet for the cost of a few meters of hose worth trying?
Any advice gratefully received ��,
Thanks Carl.
Thanks Carl.
