Daydream believer
I have been researching a new smart charger for my boat. 2- 90 ah AGM domestics & 1 redflash AGM 24ah starter. Connected with a cyrix VCR
The engine starts at the press of a button, so the starter battery gets charged by the engine easily.
Most chargers have 1 or 3 terminals , but when I enquire about them they do not seem to regulate the output to the batteries individually. ie they all go "bulk" then they all go "float" etc
Victron & Dolphin show the charger connected to the domestics. The current presumably flows across to the starter.
But as my alternator is rigged to charge the starter first that does not need so much of a charge, plus it is smaller.
When I arrive in port & plug in shore power the charger senses the domestics are very low so starts a bulk phase. Presumably the starter gets this as well. Even though it does not need it.
So what happens to the starter battery. Does it get cooked over time or does it reject the charge. Should there be some switch system to stop it once the starter is full
If the charger is fitted to the starter presumably the domestics get cut off before their time because the starter tells the charger " I am full"
So what happens & how does one do it, because as far as I can see, none of the lower cost ( sub £ 400) battery chargers, that I have looked at, deal with starter as a separate item
