dhippey
Hi Chaps,
My Dolphin engine has two sets of points located in an almost inaccessible location at the front of the engine. To adjust these means removing the engine!
While this is an easy'ish option in port it is not something I would try in anything of a seaway. So my mind wandered over to my old MG which has a 'fit and forget' set of points made by Lumenition, (it's the Magnetronic ignition system). My thoughts are would it be possible to fit something similar to the Dolphin.
So I ask have any of you converted a Dolphin petrol engine to electronic ignition with this type of point set?
If so any hints & tips?
Which parts did you use?
Thanks.
Thanks.
