ianj99
How have you wired this and can you provide a specific link to the correct one? I found one with a PS/2 fitting and 6V but no 12V option. I'm happy to cut the end off but don't want to fry it![]()
This is the GPS unit I used.
As you will see, its not cheap but works reliably and runs off 12v. Needs no setting up.
http://uk.rs-online.com/web/p/gps/7032950/
So you just need run the cable to back of the vhf, connect the supply wires to the vhf supply and the nmea out to the vhf's nmea in.
Job done!
There's no need to mount it on the pushpit - mine is just off centre attached directly to the wheelhouse roof with mastic and is below the main boom and this never causes a problem with reception.
(modern gps receivers are a lot more sensitive)
So the Navicom Rt650, with wireless remote and the above module is not much more than the cost of the Standard Horizon with wired remote but no gps. Or probably about the cost of an AIS vhf with built in gps, when one becomes available.
