uncledekka
New Member
Hi all, here's my question to the wise- if I double my engine horsepower, should I change my gearbox ratio?
I've swapped my tired old Lister HW3 for a youthful Perkins 4236. The Lister put out 36hp through a Borg Warner with 2.1:1 reduction, and the sweet spot was around 1800 rpm giving me 5 knots.
The Perkins will also be happiest around the same revs for fuel consumption, but it'll also be producing around 60hp- twice what the Lister was capable of.
Should I stick with the original box at 2.1:1, or should I get a different ratio box to take advantage of all that extra power?
I should mention that this is a heavy-displacement 35ft motorsailer, and all I really want is to achieve hull speed- around 7 knots!
(I appreciate that there will be some fettling to be done to the prop regardless)
Hope that makes sense!
