fergycool
Just noticed that the pulley on my water pump wobbles side to side if you push it. I have no idea how long this is been going on. But I've been running the engine without covers for an extended period of time as I've just had to replace the heat exchanger with associated re-plumbing! I noticed a "squeak" every 5 minutes or so. I intially thought it was the alternator/waterpump belt slipping. So I tightened it, which did kill the squeak. But of course that was just the extra tension stabilising the pulley.
There's no leak, so I'm guessing it's the bearing that needs replacing.
Is this a big job? Or is a new pump the preferred route!
(Perkins 4.270 - descendant of the L4 and forerunner of the 4.236).
Cheers,
Chris
Cheers,
Chris
