Do we 'petrol up' for the winter?
Sulley
24 Feb 2011
Berkshire
I've seen the post regarding diesel, what's the advice for petrol?
I have a V8 350 MAG petrol currently with just under half a tank of petrol.
The boat is in the water and will remain in over winter suitably equiped with heaters/dehumidifiers etc. We plan to use her regularly over winter as well.
Any recomendations?
Not the same issue with petrol, so you should be OK. Yes the tank will condensate, and you will get a bit of water in the fuel, but this to my knowledge will not create the same problem with the dreaded bug as with diesel. Your issue with petro can be deterioration of the fuel, but just over winter you will not findthis an issue. In any case you will be using much more petrol than an equivalent diesel, so the turnover of fuel is higher.
Not the same issue with petrol, so you should be OK. Yes the tank will condensate, and you will get a bit of water in the fuel, but this to my knowledge will not create the same problem with the dreaded bug as with diesel. Your issue with petro can be deterioration of the fuel, but just over winter you will not find this an issue. In any case you will be using much more petrol than an equivalent diesel, so the turnover of fuel is higher.
Empty the tank as the light hydrocarbons in the petrol will evaporate leaving a thicker less volatile mixture. That's the theory which is correct, but in practice don't worry about it. But don't put anymore in the tank until the spring.
I've used that Quicksilver additive, and AFAIC it's a waste of money. I usually leave my tank approx. 1/4 full and then chuck fresh petrol in at the start of the season. No problems for the past six years, but it's your call/money...
Thanks for all the replies and advice it's the first year I have had a boat so I'm still learning as I go!
With all the issues with diesel I just wanted to check what to do with my petrol!
