Seastoke
Or do they get more
Exactly the same as mobos, they can declare whatever usage they want. I declare 60/40 which I estimate is actually about right.Or do they get more
Or do they get more
40% reduced VAT isnt it 5% as heating your homeThe declaration you make us entirely up to you. HMRC can require anyone making any declaration other than 100% for propulsion to justify their declaration. However, I understand they have made it known they will be less likely to raise questions on someone declaring 60:40, the latter part being the non duty / vat element.
If you run a RIB you would be hard pressed to show much other than 100% for propulsion. Conversely if you own and live aboard a narrow boat using red diesel for heating and not going anywhere you could easily justify 100% for non propulsion.
Or do they get more
VAT is same rate (5%) on full or reduced duty parts.
I meant the 40% part of the split is @ 5% VAT & the 60% part of the split is 20% VAT.
Is that not correct
No all 5%
No he is right with a 60/40 split, you pay 20% VAT on 60% and 5% on 40% that is why its cheaper! The duty is the same on both.
no. the duty rates are different, vat is 5% for both. see hmrc website: http://customs.hmrc.gov.uk/channels...PROD1_029598&propertyType=document#P101_13532
You are getting your VAT and your duty confused - you pay 5% VAT on all of it but duty only on the amount declared for propulsion.Well i was wrong ( again)
So even @ the 60/40 we have paid the FULL VAT req. The split is really irrelevant we have paid the full VAT asked for
What a cock up..
What a cock up
the 5% on propulsionA cock up by whom? VAT on heating fuel for your home is 5%, so why would it be any less for heating fuel for the boat?
This is getting confusing, I was wrong on the VAT at 20% on the 60 bit, but duty is paid on both, total duty is approx 57p on road fuel, on red diesel you pay 11p (included in the 40% bit) and the extra 46p on the propulsion bit to bring it up to the road rate. Fortunately we get VAT at 5% instead of 20% you pay on white diesel.
