Do outboards have air filters?
13 Aug 2005
Bangor, County Down
In the process of ironing out a couple of problems on an old Yamaha Malta and have used the forum wisdom to find a totally blocked fuel filter (sneakily hidden inside the fuel tap!) when the above question occured to me! Well do they? Also Lakey has mentioned giving the carb a good clean out but I am buggered if I can see how it unbolts without magical bendy spanners! Anyone taken a Malta carb off?
winsbury
28 Sep 2012
None of my 2,4,6 or 8hp outboard engines do or have done but all have had fuel filters with the exception of a 1970s seagull. Strange really compared to say bike or mower engines of similar cc but perhaps its to stop damp filters causing problems
25 Feb 2010
I've never seen an air filter on an outboard. I have always assumed it was because the air is cleaner out at sea and there is unlikely to be much dust around.
VicS
13 Jul 2002
I think I have seen mention of the odd outboard with an air filter ( big Mercury ??) but generally they do not. They are not used much in dusty conditions!
My 1970s Seagulls do not have filters either , although an almost identical carb on my vintage lawn mower does have a gauze filter.
rbmatthews
15 Nov 2010
North-east Scotland
rubytuesday39.wordpress.com
The Mariner 75 Optimax certainly has an air filter - I changed ours at the last service:
http://shetlandf4.wordpress.com/2013/10/12/annual-service-2013/
The previous Mariner 75 we had also had one. The smaller outboards don't seem to - our Tohatsu 3.5 only has a manifold, but no filter.
R.
davidej
17 Nov 2004
West Mersea. north Essex
The carby comes off when you undo the long bolts that hold the black plastic 'intake manifold' (not a filter) on.
You wouldn't have a piccy please?
Took half an hour clearing he garage to get this!
Undo the two shiny bolt heads near the bottom of the picure which hold both the black plastic 'maniifold' and carby on.
Billjratt
9 Sep 2004
Firth of Clyde
Good smaller outboards don't have an airfilter but they do have a nice long plenum chamber which has enough capacity to supply air rather than water before the motor stops when submerged! This saves you from getting a hydraulic lock and damaging a con rod. No need to enquire how I know...
