Javelin
In truth I've not used it much on the yacht yet but I will once I start racing her.
In the FD, 505 and Javelin when racing it's a must.
Say you're cracking along upwind in 20 knots apparent and you're approaching a headland.
Chances are you'll get a shift and an increase in wind speed for a while until you're past it.
You could reef and then shake it later, time consuming and slow.
You could get someone to man the traveller and play that for a while though the jib will still be over powered.
You could wind on some main cunningham and also apply some extra tension on the Jib halyard which is equally if not more important.
As soon as the wind drops off make sure you release the cunningham and let of the Jib halyard again.
Foot tension is not so important.
The rule of thumb for both sails is that the top third of each sail does two thirds of the work.
In 20 to 25knots of wind coupled with the angle of heel when close hauled, the bottom third of the main is really not doing much anyway.
If there is a chop about and you need grunt to get you through it then easing a little can help but nowhere near as much as making sure the top third of each sail is set correctly.
Leech tension in the main is controlled upwind with the mainsheet and the fore and aft of the jib/genoa car. (Forward for more, aft for less)
Once you are out of the range of your traveller, usually a close to beam reach, the kicker takes over leech control from the traveller/mainsheet.
