Do i need to lube my impeller?
Tryweryn
25 May 2012
Pwllheli
Changed my impeller today and it went in no problem. I ran the engine and no problem. But was i supposed to grease it and will it cause problems?
The Speedseal people recommend silicone grease on the shaft and on the faces of the impeller. This assists removal and reduces friction when turning. Many of us ran impellers without any lube for years and never had a problem. To my mind the important thing is regular inspection and change at the slightest sign of a crack or wear.
It doesn't need additional lubrication while running normally. The grease is to prevent wear during the initial period of dry running before the pump re-fills with water. How long that period is, and hence how necessary the grease is, varies wildly depending on your plumbing arrangements and the state of wear of the pump body.
It's probably ok though.
a bit of lube helps when you are persuading it into the housing and getting the fins to lie in the right direction. in the old days we were told to use fairy liquid and watch for the suds to come out of the exhaust. it also helps in the first few seconds when there is no water to lubricate the fins but i've installed many impellors without lube and never had a failre so relax!
+1 to all of the above. I've never had a problem (and haven't lubricated any of mine with anything). Even though getting the vanes facing the right way is also a good idea, they actually reverse direction anyway (at least on my engine), pretty much every time it stops because the piston comes up to compression on the last revolution and then bounces backwards down the bore so the engine reverses for the last half a revolution. Again, it doesn't seem to do the impellers any harm.
And if you have a Vetus type water strainer, unscrew the clear cover and fill the pipes with water so that there is very little time without water.
Now I know why some of the vanes were facing the wrong way when I changed mine recently - thanks.
Silicone grease comes in different viscosities from very thick - like high melting point multipurpose mineral grease - to very thin, like engine oil.
From reading the reviews, alahol2's link looks like the thin stuff.
Having used several different types over the years, I prefer the thicker stuff although I don't suppose it makes much difference.
For the last few years I have stuck with Servisol http://www.amazon.co.uk/Servisol-Silicone-Grease-50G/dp/B000L97ZPI which is medium grade viscosity.
Richard
Nigel beat me to his reply - great minds think alike!
You are quite right, the stuff I use is fairly thin, not quite runny. I may give the Servisol a go. Thanks both
Impellors are intended to be water-lubricated, and anything else you put on them will be washed off pretty quickly in use, water-soluble or not. There might be some point in using something to help install an impellor in a dry pump; I tend to use washing-up liquid.
I usually just put a small amount of vas on the blades but you can always pull it out again if unsure if it's cold to touch don't worry
