Sy-Revolution
I'm installing a holding tank, the heads (electirc mascerator) is above WL and so is the bottom of the holding tank (just), at preset I have no vented loop fitted, just a pipe coming up to the bog and one going straight out both skin fittings below WL. All seems to work fine. I have bought a Jabsco pump to pump out the holding tank, on their literature they say that if the outlet skin fitting is below WL then one has to fit a vented loop at least 20cm above WL at all angles of heel/trim.
I'm going to find it hard to fit one in so is it nessesary and if so why, when without the holding tank my system works just fine?
Alternatively I could plumb in a skin fitting outlet above WL, has anyone done this? If so is there a staining problem on your gelcoat?
Cheers,
Crispin
Cheers,
Crispin
