Jim@sea
The boat I am improving (23'6 Colvic Watson) has a Kemp Mast and whilst the mast is on the floor I want to renew the Halyards.
I took the old ones out and threaded a temporary rope through.
Using a Vernier Gauge shows that the old ones are 8mm in places and 9mm in other places. But as the boat is 30 years old it would have been an Imperial measurement.
But at a chandlers today I saw some 10mm rope which looked better and with a Vernier Gauge measures out at 9.5mm
And the cheap (Builders Merchant Polypropylene) which I threaded through measures 10mm and it goes through the block things at the top.
Some of the original Halyard is worn and perhaps stretched
So the question is, A.
Can I go to 10mm or should I order 8mm as it appears that you cant buy 9mm
Should I ring Kemp Masts and ask them what size rope to use.
