DIY Tidal Curves
obmij
30 Nov 2005
How does one go about plotting a tidal curve i.e how does the almanac go about it?
Got on to this line of thinking because Holyhead tidal curve is too small to accommodate some of its secondary ports, so when working out Conwy for example you have to use a bodge, such as halving the scale for Holyhead or using a similar curve with a bigger range.
Both workable of course (as is a quick mental 12ths calc) but I would like to do it properly.
It would also be interesting to have proper tidal curves for some secondary ports, printed and ready to go.
This is more for interest rather than practical purposes I'm aware there are 'workarounds' (and software)
Cheers
Do you have a source of data other then the tidal curve for the primary port? That's usually what you use to determine intermediate heights, even though it is not a really accurate method for all secondary ports.
If you really do have a separate source of data, use Excel and fit a curve to it.
If you have an iPhone or iPad then Tides Planner by Tucabo is your friend...
+1
Can feel a little overcomplicated at first, but once you get used to it it's indispensable. Does tidal streams too, either fully dynamic or (my preference) extracts from the Admiralty atlases with the times set up for the given day.
I have a love/hate relationship with Fourier after all the suff I did with in on my degree :)
I have used it a lot for image analysis, and can't understand why people insist on doing things badly in the Space domain when they are easy and precise in the Fourier domain. I've even developed a technique for doing shape from shading in the frequency domain; sadly it turned out someone else had done it before, but i was still proud of my mathematical skill!
Like wind or a change in atmospheric pressure. Unusual?
If it's enough to significantly change the sea-level, it is unusual (and probably cruel as well!). No prediction is reliable to the level of tens of centimetres, for a multitude of reasons, and attempting to do tidal calculations to that accuracy is not worth the bother. You can attempt to correct for barometric pressure (there is a fairly good relationship), but the effect of wind is so dependent on the local configuration of the sea-bed that it isn't feasible to do it reliably.
