VandKoala
Active Member
Our (brass?) rudder gland has crumpled and we had to replace it.
We went with a bronze Vetus rudder gland. It has two O-rings inside it, one at the bottom and one at the top.
The problem: Dropping the rudder to replace the o-rings after they wear out will not be desirable as it is skeg-hung and completely glassed in on skeg.
The idea: Create an additional sealing solution at the top, that can be replaced without dropping the rudder.
I have made a 3d-printed prototype, that fits standard 40x52x7 gasket/seal (1) for the shaft (2).
I could order one machined in bronze, but I am not sure this solution would work overall. The top of the bronze gland is slightly above/at water level, I do not expect much pressure.
Are there any experts here with practical experience that could tell me if this should work or not and why?
Cheers!
Koala
Cheers!
Koala
