pcatterall
Now we are doing more of this stern too mooring we want to alter our pushpit so we can walk through it rather than staggering up the gang plank and climbing over it.
I have worked out what to do and it seems that I can get tube and fittings from Sea Screw, a few questions arise.
I know that I can cut SS tube here at home using a thin disk in my 4“ angle grinder. I have not got a grinder on my boat ( in Italy) but understand that A hacksaw with 14 teeth per inch will cut 25mm 2mm wall tube OK, is this the case and are there any recommendations about where to buy suitable ( 12“) blades?
The Sea Screw fittings have little grub screws with points will these just grip the inner tube OK or is there advantage in making a little ‘counter sunk’ type hole for the screw point to ‘locate’ in?
I really need to fit a 20mm tube at right angles to a 25mm tube, there are lots of T type fittings for 25 and for 20 mm tube but I really need an ‘unequal T’ for the job, any ideas if I can locate one anywhere/ If not then hopefully I can fit the 20 mm tube into some 25mm and the 25mm to the T ?
Grateful as always for any input on this.
