noelex
Fine, but a regulator is more inefficient. If you are dropping from, say, 12v to 3v, most of your power is lost as heat. As always these things are a compromise, but connecting in series would avoid that heat loss.
LED's have a remarkably long life. They won't normally blow when used properly.
Good LED drivers have efficiencies of about 90-95%. They are available as pre-built modules,
Without a driver you can have good brightness, or a long life, take your pick.
http://www.cutter.com.au/proddetail.php?prod=cut131
