DIY in water hull cleaning..
Take one sausage fender glue 3 or 4 scotch pads to it then attach lines at both ends long enough that you and a friend can have the ends on either side of the boat. you pull up from your side then let him pull up from his side. we have used this method to clean our Colvic Watson 32 long keel with good results.
We have a Larson 254 Cabrio and I'm just wondering if there is something that can be done once a month or so that can keep the hull below the waterline clear of growth reducing the frequency it has to be taken out and jetwashed/anti-fouled..
Anyone know of any good ways to clean the hull in the water without diving under the boat?
Thanks..
Just go and get a Hullmate, like I did.
They work.
