Adetheheat
Is the displacement speed concept applicable to planing hulls or just displacement hulls?
Hull speed in knots is reckoned to be 1.34 x sqrt(waterline length in feet).Hi,
In practice, yes.
If you think about fuel economy, you will find it about 2 knots below the theoretical hull speed.
Waterline length (as far as I have googled) is 50ft.A really graphic illustration of westerman's great explanation is to look at the fuel consumption figures in the boat tests in MBY Magazine. At displacement speeds the fuel consumption can often double between 8 and 10 kts - look at their l/nm figures and the expected range. My mate found exactly this with his Swift Trawler 52, just by cruising at 9kts rather than 10 he almost halved his fuel consumption. Of course where this step occurs depends on hull length.
Similarly, I had a 19.5 ft sports boat with a Yamaha 115 and unless you ran at sub- 4kts she more efficient at 20kts.
Not sure that's always valid with power boat hulls.Hull speed in knots is reckoned to be 1.34 x sqrt(waterline length in feet).
For good fuel economy, you don't want to exceed 1.0 x sqrt(waterline length in feet).
Below 1.0 things are pretty linear. About 1.0 you start getting exponential. And at 1.34 the exponential is almost vertical.
Below 1.0, fuel consumption per nautical mile does not change much with speed.
I.e. the benefit of going at 0.5 instead of 1.0 is marginal (wind and current and other factors will tend to override any theoretical difference).
At displacement speed a Swift trawler has brick shaped stern with the lower bit in the water.Not sure that's always valid with power boat hulls.
If you've got a lot of transom immersed at rest/low speed, it's very draggy.
You would probably get about twice the miles per gallon at 6 knots vs at 9 knots.Just on this topic. I plan to do some long journeys at displacement on my Targa 48. At what point would I become uneconomical? Assuming 8 or 9 knots is ok for economic cruising. IPS 600, D6 435 engines
There is no real substitute for actual measurement of consumption at different speeds.Just on this topic. I plan to do some long journeys at displacement on my Targa 48. At what point would I become uneconomical? Assuming 8 or 9 knots is ok for economic cruising. IPS 600, D6 435 engines
Everyone seems to have forgot about tides. Working hull speed out is all well and good, but the actual SOG will depend on tidal effects. If hull speed is 6 knots and you're in an area where the tides run at up to 2 knots (just for instance), SOG will vary from 4 to 8 knots.Just on this topic. I plan to do some long journeys at displacement on my Targa 48. At what point would I become uneconomical? Assuming 8 or 9 knots is ok for economic cruising. IPS 600, D6 435 engines
Exactly what i meant in post #17 IanMy Southerly 46 has theoretical hull speed of just over 9knots. It's definitly a displaced hull. At 6.5 to 7knots I use about 2L per hour, flat out at 9knots plus, it's more like 10L per hour.
But I have had it surfing at 13knots, that's just short bursts going down the face of a wave, with gravity assistance. I guess it must be planing at that speed, but it's not a speed I can get close to in flat water.
I often see motor yachts, hurrying along generating massive bow waves and big wake, and wonder why they are pushing the boat that hard, when slowing down a couple of knots would make a significant difference to their fuel consumption.
