hobiecat
The main negative is that costs are higher for a catamaran for a given length. With the two hulls there is simply more surface area and fibreglass needed. Systems must be duplicated in both hulls. Pumps, engines, electrical and plumbing systems, etc. However you end up with is more usable space for a given length. Fuel costs are considerably less. Tank testing was recently carried out and simulated huge breaking beam seas and the power catamaran could not be rolled over but the similar sized monohull power vessel could. In addition, in following seas, the relatively narrow hulls of a catamaran track straight and true with none of the usual monohull broaching tendencies. Although the displacement catamaran will have a wave resistance-determined hull speed just like the monohull, this hull speed will be very much higher. The speed of the displacement catamaran is largely a function of the fineness ratio of the hulls. Realistically, the upper speed range for a displacement catamaran hull is about 20-24 knots. It is advantageous in terms of fuel economy/horsepower requirements to keep your top speed, and particularly your cruising speed, as far down the resistance curve as is practically possible. The cushion of air created between the hulls acts like a shock absorber and creates a far more comfortable ride. Juggling the variables, inevitably, seems to mean a fuel efficient, semi-displacement catamaran hull which achieves cruising speeds in the 15-20 knot range as a better boat with a proviso on price. Better performance and comfort is achieved on catamarans with modern, lightweight strong construction methods.
