Talulah
We have 10mm 1x19 rigging.
We have the largest Felco cutters at a cost of about £300. Meant to cut up to 12mm.
There is absolutely no way the Felco cutters can be used to cut 10mm rigging on board. I had some of the rigging replaced where the rigger used the same Felco cutter. He had to use all of his weight and energy to cut through the stuff. In his workshop he was knackered having only cut 2 lengths.
Meanwhile on board I use a rechargeable angle grinder with 1mm thick blade. Cuts through in seconds. (By having Lithium batteries you don't have to worry about finding the batteries discharged when you come to use it. They hold their charge.)
We also have on board the 'Shoot-It' device which uses blank .22 cartridges to shoot a bolt that shears the wire.
The Felco cutter is now left at home.
