Disimilar metals in coolant system
What are the recommended hosetails and fittings to use in the closed cooling system into aluminium? Does it matter when it is anti-freezed water or should I be picky?
The antifreeze should have been diluted with distilled water or water with a very low dissolved solids content. It probably does not therefore matter however if it troubles you then use plastic fittings as PR suggests
https://www.asap-supplies.com/fittings-valves-strainers/fittings/non-metallic-fittings
