Disaster struck!!!!!!!!
ianainge
15 Jan 2003
Hampshire
After saying goodbye to all yesterday morning I spent the afternoon in The Beaulie river in brilliant sunshine had some lunch ,came back over at 5.00pm .on crossing the main channel at Cowshott heard a massive thump and loss of power on port engine. Got myself out of the channel and checked shaft inside, appeared to be ok but no drive, looks like Ive hit something and snapped the shaft.$*&!)%^&$£&*.
zefender
9 Jul 2001
quacious
Re: Beers found!
I remember putting some beers somewhere safe on your boat. They seemed to wedge in tightly either side of a metal thingie by the engine, I thought. If they are damaged, on account of poor seamanship/excessive revving etc, can you make sure you replace them in time for the next visit, so I'm not out of pocket?
;-) hope all's not horrifically expensive to fix.
ianainge
15 Jan 2003
Hampshire
Apparently Ive got no pins on these shafts, and when i select forward gear the shaft is turning and theres no water disturbence at the stern at all, if if id lost 3 blades there would be something, plus a lot of vibration, ill find out today.And aparently the prop cant just come off as in forward gear its being pushed on to the shaft different in reverse of couse.
duncan
Home mid Kent - Boat @ Poole
sorry to hear that Ian - and after all your efforts on the catering ffront etc were such a success.
After last years breakdown in the middle of Poole bay on the way home this year was a breeze......which is just as well as I don't think I was up to much in the way of fixing ....
Hope it's not too many pennies - too much time
<hr width=100% size=1>madesco madidum ..../forums/images/icons/smile.gif
Mike21
10 Dec 2003
South Coast
You may possibly have lost the prop completely. Had this once on a P52, lock tabs on cone nut not bent over correctly, it came off then the prop .
D
Deleted User YDKXO
Check that the engine mountings are not broken. I had a similar thing happen on a Princess 435. The engine mounting bolts corroded (without me noticing)and finally failed in mid Channel causing the engine to fall off it's mountings and snap the universal joint between the gearbox and shaft. When I checked the other engine, 3 out of 4 mounting bolts were sheared also and that engine was being held in place by one bolt only
barryjl
23 Mar 2003
Hampshire
Really sorry to hear about that mate - sounds serious and expensive - if you did strike something I presume it's an insurance job??
<hr width=100% size=1>There's no problems..just opportunities
jfm
Jersey/Antibes
Eek you've lost the whole prop. Locktabs not done properly perhaps. On inward turning props the port prop nut (which has a right-hand thread) relies on the locktabs more. At least one new prop is loads cheaper than a new shaft etc........or could you retrace your position well enuf to get a diver to retrieve it? I guess not, needle in haystack?
ianainge
15 Jan 2003
Hampshire
only surveyed 4 weeks ago you would hope he cheked those things,if that is the case is my insurance going to cover it?, they could`nt lift her today so have to wait till tomorrow now.
tcm
11 Jan 2002
Caribbean at the moment
Re: the curse of mrs tcm
The fault will probably be due to mrs tcm having been on board the boat the previous day, so you had better send her the invoice. She is normally very reasonable about this so i will expain to her (again) that, as usual, the boat from which she has just alighted from has busted, and it's entirely her fault.
hope not too awful :-(
BrendanS
11 Jun 2002
Tesla in Space
Sh*t!, not the ending to a great weekend that anyone would want!
Hope it's not too painful to repair, whatever the cause
<hr width=100% size=1>Catapultam habeo. Nisi pecuniam omnem mihi dabris, ad caput tuum saxum immane mittam.
longjohnsilver
30 May 2001
Nah, can't be the shaft, should imagine yours is probably 1.75" or more, virtually impossible to snap!! Either the flexible coupling which is most likely, or you've lost yer prop.
Before lifting her out I presume you've checked the coupling? If it is that it's an easy job and even better no lift out required.
paulineb
I no longer live in Hope
RichardP had some problems on the way back to Brighton too. He had an engine go on him. We went into Sparkes, left his boat there and everyone came back on Tommy. It looks like a turbo problem.
<hr width=100% size=1>Pxx
<A target="_blank" HREF=http://www.paulinebeddoes.co.uk/php-cgi/gallery2>Perils of Pauline in Pics</A>
Col
14 Oct 2001
Berks
A Ha!!
Someone challenging me for the "prop losing title" Methinks
<hr width=100% size=1><A target="_blank" HREF=http://www.arweb.co.uk/argallery/colspics> Cols Picture Album</A>
Geoffs
15 Jun 2001
Wantage,Oxfordshire
I did look for you off Bournemouth when I came through, but guessed you must have been ok this year/forums/images/icons/smile.gif
<hr width=100% size=1>Old Chinese proverb 'Man who sail boat into rice field, soon get into paddy'
PhilF
18 Jun 2001
In a state
why is it cars nowadays seem to run forever, but boats, that seem to enjoy much more TLC, seem to break down at the first opportunity.
Is it the invasiveness of saltwater or just simple crap mechanical, tech and build quality.
Just a question, but I never get in the car expecting it to break down but always expect it on the water.
paulineb
erm, why are you asking me that question Phil? I just eat, drink and sleep on them - but I do all three rather well
