owen-cox
Steve
I'm having the exact same problem.
But I have taken apart my thermostat (Waeco CR50 fridge) as you suggest but I don't understand the part about disconnecting the yellow cable because when I do this the fridge doesn't work!
Surely I need this yellow wire to connect somewhere to complete the circuit?
Please could you clarify what I should do. Thanks.
What I believe he means is that Waeco install a resistor with a two spade connectors on a male and female with yellow shrink wrap around it. this goes in line with the thermostat. this lifts the cut out voltage. you simply un plug it at both ends and replace the wire that it came of to the free terminal you unplugged the resistor from. thsi will give you the standard voltage cut out.
