Dave_Seager
My Walker Bay 8 already has a conventional dinghy bung fitted. It has a built in non return valve in case you forget to put the plug in as well. However, looking a photographs on-line it appears that some have them and some do not.
The only problem is that it is not at the lowest point of the transom due to the wheel fitting so it leaves a little water in the hollow keel section. If you have a Walker Bay dinghy with no drain plug it would be very easy to fit one.
