Dinghy cruising help
joeirish
11 Oct 2002
Ireland
Any views on light weight sailing dinghies that have been built from kits?
I am considering a 14 ft LOA by 5 ft beam plywood/epoxy clinker dinghy with laminated centre plate. She is gaff rigged with 80 sq feet of sail, but only weighs 170 lbs. I have been advised that I will spend most of my time capsized (and wet!) as she is so light. I plan to sail her two up not single handed but in a very big lake here in Ireland that is more like coastal waters than inland waters.
<hr width=100% size=1>Joe Griffin
a light dinghy is not inherently unstable after all, a rubber dinghy is pretty light but they are damned hard to turn over.
what affects stability is beam and deadrise. Explanation: the nearer a dinghy is to a flat wide shallow box the more stable it will be. unstable cross-section shapes resemble a triangle or semicircle.
look at the shape of your boat: is the bottom flat or a shallow V? if it is, OK. if it is deep V or deep and rounded it will be tippy.
Re: How good are you.
If you're a confident, experienced dinghy sailor it might be a hoot.
Uffa Fox cruised widely in his Int Canoe but he was a bit exceptional.
It also depends what you mean by cruising. Most planing dinghies don't carry weight well. So loading it with home comforts won't help.
