pandos
Hi I want to remove keel from Elizabethan 29, it is external cast iron.
The keel bolts are glassed over inside the bilge, under the keel I can see indentations in the casting as if a threaded insert was fitted up into the base of the keel..
Question. how do these keel bolts work, are they Bolts up from underneath with nuts inside the boat or are they bolts threaded down into the keel,
What do I do if I shear one off.
I need the keel off so that I can move / manoeuvre the boat into my garden to do a refit.
all help appreciated
Tony.
Tony.
