D
Deleted User YDKXO
I'm looking at a technical report on various tests carried out by a Cat dealer on two Cat 3196 engines in the same boat. These tests were carried out during a seatrial and there is very little difference between most of the parameters measured except in one area. At max rpm, the port engine appears to be consuming about 10% less fuel in terms of litres/hour than the starboard engine. In addition, the measured fuel pressure in the port engine is abour 10% higher than starboard and, similarly, the turbo boost pressure is 5% higher. The measured rpm of both engines at max speed were virtually identical.
Is this variation acceptable or should I be concerned? Could the variation be caused by differences between the props?
