D
Deleted User YDKXO
I don't think that's the whole picture mike. On those numbers, the 50kt boat will burn 104% of its no-tide fuel on any given trip, whereas the slow boat will burn 167% of its no-tide fuel burn
At infinite speed the tide has no effect,. At the same speed at the tide, it has infinite effect. Just like airport travelators - the faster you walk/jog the less they help you, whereas if you stand still they help you 100%
There is a speed of foul tide at which it makes more sense to plane at 20knots than pootle. (Not in the Med of course!)
I'm not arguing with the % effect on your SOG or fuel burn. Obviously the faster you go the less will be the % effect on your SOG and fuel burn. My argument was with asteven221's suggestion that a boat could somehow 'fly on top of the water' at planing speed to reduce the effect of the tide, which, with all due respect, is nonsense.
With regard to asteven221's actual situation as to whether its better to maintain 7.5kts against a 2kt tide or speed up to 20kts, that should be easy to work out. He says he gets 2.75mpg at 7.5kts. Lets assume for sake of argument that he gets 1.0mpg at 20kts. A simple calculation tells you that, with a foul tide of 2kts, his mpg drops to 2.0mpg at 7.5kts through the water (5.5kts SOG) and 0.9mpg at 20kts through the water (18kts SOG) so he's still better off maintaining his 7.5kt speed.
To illustrate your travelator point, if you do a few more calcs, you can work out that he is better off maintaining 7.5kts upto to a foul tide of about 5.5kts. Beyond that, he's better off speeding up to 20kts. But obviously that is only the case for this particular combination of speeds and mpg
