pandos
I have posted this problem in the past but I have still not been able to cure it, perhaps someone will have a new suggestion.
My md21b is getting air into its guts from somewhere after it is stopped over night.
It did not have this problem when I bought it but it did develope the diesil bug and the pump had to be removed and serviced.
I have removed and refitted the injector pump the lift pump and all the other bits and pieces that go along with them but I cannot find the cause of the problem. there is no apparent diesil leak, yet whenever I leave the boat overnight it has to be bled to start the engine the next day.
Any suggestions would be welcome. I intend to change the filters and as many of the fuel lines as I can tomorrow, but the most fruastrating part is that I will not know if this has cured the problem untiL the next day.
Thanks in advance.
Tony
Thanks in advance.
Tony
