chas
I have had a leak in my diesl tank all season - not much - about a pint a week and a bit more if it was rough. The tank is mild steel, about 45 gallons, 30 years old and is under the cockpit locker. The problem is that, although I can manoeuver it in the locker, it is too big to come out through the lid.
I have now found the leak - the tank itself is in amazingly good condition both inside and out. It looks to me as if the leak was caused by an imperfection in the steel rather than rusting through. I have cleaned it back to good metal and now have a small slit about 1/2 inch long and 1/4 inch wide.
Obviously, it would help if I could repair it. Can it be welded? it is surrounded by glassfibre and is a diesel tank. Is there any propriety filler I could use and perhaps glass in the repair? Any advice would be welcome.
Another thing - when I took the inspection cover off, it was sealed in with a cork gasket. What should I use to seal it back?
Thanks for any help
Thanks for any help
