TimfromMersea
Strange problem last weekend. Engine (Volvo 2020) connected to Brunton's Autoprop via standard shaft, i.e. not a sail drive. Running perfectly to leave moorings at West Mersea, then when approaching Woolverstone, could only get 1900 rpm under load. It span to 3750 rpm in neutral. Running OK though, no vibration etc.
Tried ahead and astern several times, still the same, could only get 1900 rpm irrespective of throttle opening.
Arrived Woolverstone, everything appeared normal.
The next day, topped up with diesel. Then leave early AM with no wind, and everything is fine - and remained so.
Any ideas? tank breather seems fine so unlikely to be a vacuum in the tank.
Baffled me and so any advice/thoughts welcome!
