jaminb
My winter maintenance has resulted in diesel leaks.
Leak 1. I replaced the primary filter with a copy Racor filter. This appears to weeping diesel from the threads of the tails / barbs. I had to buy new genuine racor tails that were for 8mm pipe but did remember to put the sealing washers in before I screwed in.
Leak 2. I brimmed the diesel tank whilst out of the water and it appears the pressure has caused a leak around the sender unit. This is held in place with 6 self tapers screwed into the plastic fuel tank and looks like it could pull out with the slightest knock.
Heldite appears to be a forum past recommendation but this is not suitable for ethanol and I think diesel now has an element of ethanol in it?
Any other recommendations please? thanks
