Boeingdr
I have a slight weep of diesel from the fuel cock from the base of my diesel tank. This has been the case since I bought the boat but it has been sufficiently small that a rag around the tap has soaked up the fuel.
I have just had a fuel feed attached downstream of this to a new Eberspacher heater.
Since then an amount of fuel seems to be collecting in the bilge (not sure if this is combined with a rainwater leak which I have just tried to repair from the cockpit table fitting above).
If the leak has got worse I may be forced to replace the fuel cock.
This will involve draining the tank, its a pretty old fuel tank I think, I am worried that draining it will disturb all the contaminants at the base of the tank and cause problems with the fuel system later.
Does anybody have experience of draining the tank, advice, warnings etc..
