Diesel heater glow plug conundrum
Hdp160
20 Apr 2021
Hi again WightMistress..
Is it me? .... I've downloaded your attachment but it appears to be blank.
I carefully reread the thread above and see that a Beru 0100 221 151 has been mentioned.
Does anyone know if that is the glow plug Wallas fit into the XC Duo hob/heater the one detailed elsewhere as 362502.
Thanks in anticipation
Nick
  • Like
Reactions: Ink
Hdp160
20 Apr 2021
Motor factor near me confirmed that Bosch 0250202096 £12 Inc vat is a direct equivalent to a Beru 0100 221 151
Hope that helps someone in the future.
BTW snapped Bosch one up on Ebay for £7:57 Inc p&p
Nick
Spenniz
29 Sep 2021
Nick
Wallas 362502 seems to be for most Wallas heaters:
Wallas | Part search | Varaosat | Glow plug 11 V (362502)
Spenniz
29 Sep 2021
I bought the Bosch 0250202096. I'm going to try it in my Wallas m2600 ( cabin heater) I'll let you know if it works or maybe someone else has already tried it?
WightMistress
5 Jan 2014
Sorry about the download issue, not sure what the problem is. Anyway, a bit further up the string I posted a list of equivalent glow plugs.
I have just copied it and pasted it here again for you:
I have just done a search using the Beru number and have come up with these as compatible equivalents:
Beru 0100 221 151
Could also be Bosch Diesel Glow Heater Plug 0250202096
(Notes on this model here☺This part is equivalent to the following part numbers: BOSCH: 42, BOSCH: GLP042, LEXUS: 87343 20010, LEXUS: 87343-30010, TOYOTA: 19850 45030, TOYOTA: 19850 45031, TOYOTA: 19850 54010, TOYOTA: 19850 54030, TOYOTA: 19850 54031, TOYOTA: 19850 54090, TOYOTA: 19850 54140, TOYOTA: 19850 54150, TOYOTA: 87343 20010, TOYOTA: 87343 30010, VW: J19 850 540 90, BERU: 0 100 221 151, BERU: 0 100 226 243, BERU: 0 100 226 311, BERU: 688 MJ, BERU: 968 MJ, BERU: GV 688, BERU: GV 968, CHAMPION: CH 154, DENSO: 067100-1270, DENSO: 067100-1630, DENSO: 067100-1710, DENSO: DG-218, DENSO: DG-221, DENSO: DG-242, DENSO: DG-400, DENSO: DG-401, NGK: 2951, NGK: 5376, NGK: DG211, NGK: Y-118 T, NGK: Y-118 T1, NGK: Y-715 R, ZEXEL: 407804-0100Notes: Spanner Size: 12, Connector type: M 4, Rated Voltage [V]: 11, Length [mm]: 92, Thread Size: M 10 x 1,25, Tightening torque from [Nm]: 15, Tightening torque to [Nm]: 20, Fitting Depth [mm]: 32, Cone Pitch: 93, Glow Plug Type: after-glow capable
I hope this helps. Please lettuce snow if you have further problems..
Regards,
Steve
Hdp160
20 Apr 2021
Beru 0100 221 151
(Notes on this model hereView attachment 123428This part is equivalent to the following part numbers: BOSCH: 42, BOSCH: GLP042, LEXUS: 87343 20010, LEXUS: 87343-30010, TOYOTA: 19850 45030, TOYOTA: 19850 45031, TOYOTA: 19850 54010, TOYOTA: 19850 54030, TOYOTA: 19850 54031, TOYOTA: 19850 54090, TOYOTA: 19850 54140, TOYOTA: 19850 54150, TOYOTA: 87343 20010, TOYOTA: 87343 30010, VW: J19 850 540 90, BERU: 0 100 221 151, BERU: 0 100 226 243, BERU: 0 100 226 311, BERU: 688 MJ, BERU: 968 MJ, BERU: GV 688, BERU: GV 968, CHAMPION: CH 154, DENSO: 067100-1270, DENSO: 067100-1630, DENSO: 067100-1710, DENSO: DG-218, DENSO: DG-221, DENSO: DG-242, DENSO: DG-400, DENSO: DG-401, NGK: 2951, NGK: 5376, NGK: DG211, NGK: Y-118 T, NGK: Y-118 T1, NGK: Y-715 R, ZEXEL: 407804-0100Notes: Spanner Size: 12, Connector type: M 4, Rated Voltage [V]: 11, Length [mm]: 92, Thread Size: M 10 x 1,25, Tightening torque from [Nm]: 15, Tightening torque to [Nm]: 20, Fitting Depth [mm]: 32, Cone Pitch: 93, Glow Plug Type: after-glow capable
Regards,
Steve
Thank you
Spenniz
29 Sep 2021
Do let us know.
Glow plug Fit and I got the combustion started. But the heater didn't start as it should. Not sure if it's related to the glow plug or some other issue. FYI the glow plug already mounted in my unit was:
Bosch 0 250 202 006.
Hdp160
20 Apr 2021
To avoid confusion ending 006 or 096
Spenniz
29 Sep 2021
I'm sorry to be the bringer of bad news but the Bosch glow plug that I bought for my Wallas cabin heater might not be the right one...
I managed to get my heater going a couple of times but I wasn't reliable. I finally gave up and bought the 65$ (!) Glow plug from Wallas and now it seems to work a lot better. Starts every time I try it, At least so far...
Anyway the Wallas spec glow plug is:
Beru 0 100 221 151
