richardsussex
Have a stainless steel tank on 5-year old boat. Only access is hole for fuel sender unit.
I am getting a bit of sludge forming in the bottom of the tank, It's a black tarry mess – slightly gritty - and is now a couple of mm deep (it has got worse over the past year). From reading the threads on here I know a lot of yotties have this problem, but what's the best way of getting rid of it, or stopping it getting worse?
My marina has access to a pump for "fuel polishing" (presumably for filtering out mould and dirt) but how do you get rid of the tar? A vacuum pipe isn’t much help as tank has internal baffles. I have looked on the net and there are some things mentioned like Exocet and Soltron. I have only the fuel gauge aperture as access. And it's a big tank.
The general impression I am getting is that diesel is an unstable fuel and its quality has got worse over the years, and that at least road diesel is reported to have been getting more additivies to prevent deposits. No mention of the same thing happening to red diesel. Even if I changed to yellow diesel tomorrow I still have sludge in my tank which is a worry to me next time I go out in a reasonable chop.
Have used Grotamar71 fuel additive (Best buy in more than one ybw test) since new and the fuel is clean and clear. No mould. Filters not getting clogged up.
What I need is some sort of solvent that will dissolve the tar and leave it in suspension to be pumped out. I would reduce level of fuel in tank as far as I could, put in said product and then pump tank dry and dispose of the dirty fuel, and then replace the good stuff.
All comments and suggestions gratefully received. Thanks
